CHMOD
CHMOD
Indlægaf majlw » ons okt 15, 2008 12:01
Hjælp! Har endelig fundet ud af hvordan jeg gør men aner ikke hvad CHMOD er?
1.Create a directory on your server ( e.g. cutenews ) - OK2.Upload the content of the cutenews.1.x.x.zip to the directory you created in step 1 - OK3.Now you must CHMOD (or CHMOD) the data directory and all files and folders under the data/ directory to 777. This is necessary to write and edit the news and other data to the db files, and allows you to upload images to the upimages folder. Note that some servers (windows types) don’t have the chmod options and don’t always need changing. Chmodding is usually done by selecting the file you want to chmod, right click and choose for the option properties or permissions. Though more detailed information we can not provide as the procedure differs from ftp client to ftp client. If you have windows hosting, you should ask your host on how to change permissions. As the tool to do this differs from host to host. - Not done!
4.Finally, go to http://www.yoursite.com/cutenews/index.php with you favorite browser and follow the instructions. - kan jeg godt men så har jeg et problem
Majlw
majlw
Re: CHMOD
Indlægaf majlw » ons okt 15, 2008 12:05
Det er denne fejl jeg får:
Sorry but installer can not write to file ./data/users.db.php,
please check if file exist and if it is properly CHMOD`ed
Tænkte at du sikkert gerne ville have den med
Majlw
majlw
Re: CHMOD
Indlægaf Kim Ludvigsen » ons okt 15, 2008 12:19
Serveren benytter sikkert Linux, der beskytter filer mod at blive skrevet til, medmindre man har skriverettigheder. CHMOD er en metode til at håndtere fil-rettigheder, herunder skriverettigheder.
Hvis du bruger et ftp-program, giver det sikkert mulighed for at ændre skriverettighederne (søg i programmets hjælp efter CHMOD). Ellers kan du muligvis finde hjælp på din internetudbyders hjemmeside eller hos deres support.
Re: CHMOD
Indlægaf majlw » ons okt 15, 2008 13:31
Hmm. kan du slet ikke hjælpe, min support er ikke helt så god til at skrive tilbage.
Jeg har hermed linket til selve siden http://cutephp.com/
Måske du kunne finde en løsning på mit poblem?
Majlw
majlw
Re: CHMOD
Indlægaf Klattrup » ons okt 15, 2008 13:48
Hvilket program har du brugt til at overføre filerne til dit websted (altså de filer som skal CHMOD til 777)
Re: CHMOD
Indlægaf Kim Ludvigsen » ons okt 15, 2008 13:57
Problemet har som sådan ikke noget med cutephp at gøre, selvom det er en af dets filer, der udløser fejlen.
Problemet er, at dit webhotel skrivebeskytter filer. Og at cutephp har brug for at kunne skrive til filen ./data/users.db.php, hvad cutephp altså ikke får lov til.
Løsningen er at fjerne skrivebeskyttelsen på ./data/users.db.php, og det kan sandsynligvis gøres i dit ftp-program, hvis du bruger sådan et.
Hvis du ikke bruger et ftp-program, kan du downloade et og prøve at finde ud af, hvordan du fjerner skrivebeskyttelsen på en fil - søg på CHMOD i programmets hjælpefunktion.
Ellers er der ingen vej uden om webhotelelts hjælpesider/support - og de vil sikkert foreslå det samme, som jeg foreslår ovenfor. Altså at bruge et ftp-program til at fjerne skrivebeskyttelsen på den pågældende fil.
Re: CHMOD
Indlægaf Jørgen Rasmussen » ons okt 15, 2008 14:57
Hej Majlw
Hvis jeg ellers har forstået dit problem rigtigt, så kan programmet FileZilla nemt ændre skrive/læserettigheder. http://filezilla-project.org/
Hvis du bruger Firefox, kan jeg anbefale udvidelsen FireFTP, med den kan du også let ændre det. http://fireftp.mozdev.org/all.html
I begge programmer højreklikker man på filen på serversiden og vælger egenskaber.
Re: CHMOD
Indlægaf majlw » ons okt 15, 2008 15:28
nu har jeg så lært at man kan gøre filerne ikke skrivebeskyttet.
Men når jeg så gør det må selve mappe cutenews på min server, lader det også til at det virker. Men det gør det så ikke.
Så kan jeg forstå at der igen anden udvej er end enten at droppe det eller kontakte mit meget mget langsome webhotel's support? :(
Her er det jeg får afvide, når jeg vil installerer systemet!
File / Folder Current CHMOD value Status
/srv/www/vhosts/majlw.dk/httpdocs/cutenews/data/ 555 Not Writable
/srv/www/vhosts/majlw.dk/httpdocs/cutenews/data/category.db.php 755 Not Writable
/srv/www/vhosts/majlw.dk/httpdocs/cutenews/data/ipban.db.php 755 Not Writable
/srv/www/vhosts/majlw.dk/httpdocs/cutenews/data/flood.db.php 755 Not Writable
/srv/www/vhosts/majlw.dk/httpdocs/cutenews/data/auto_archive.db.php 755 Not Writable
/srv/www/vhosts/majlw.dk/httpdocs/cutenews/data/rss.tpl 755 Not Writable
/srv/www/vhosts/majlw.dk/httpdocs/cutenews/data/config.php 755 Not Writable
/srv/www/vhosts/majlw.dk/httpdocs/cutenews/data/upimages 755 Not Writable
/srv/www/vhosts/majlw.dk/httpdocs/cutenews/data/backup 755 Not Writable
/srv/www/vhosts/majlw.dk/httpdocs/cutenews/data/Headlines.tpl 755 Not Writable
/srv/www/vhosts/majlw.dk/httpdocs/cutenews/data/postponed_news.txt 755 Not Writable
/srv/www/vhosts/majlw.dk/httpdocs/cutenews/data/archives 755 Not Writable
/srv/www/vhosts/majlw.dk/httpdocs/cutenews/data/comments.txt 755 Not Writable
/srv/www/vhosts/majlw.dk/httpdocs/cutenews/data/news.txt 755 Not Writable
/srv/www/vhosts/majlw.dk/httpdocs/cutenews/data/cat.num.php 755 Not Writable
/srv/www/vhosts/majlw.dk/httpdocs/cutenews/data/users.db.php 755 Not Writable
/srv/www/vhosts/majlw.dk/httpdocs/cutenews/data/unapproved_news.txt 755 Not Writable
/srv/www/vhosts/majlw.dk/httpdocs/cutenews/data/Default.tpl 755 Not Writable
/srv/www/vhosts/majlw.dk/httpdocs/cutenews/data/rss_config.php 755 Not Writable
Majlw
majlw
Re: CHMOD
Indlægaf Bjarne Krogh Hansen » ons okt 15, 2008 15:30
Jeg bruger selv Vistas til at overfører filer til mit webhotel, jeg har brugt vejledningen fra Kims hæfte om KompoZer.
Når jeg højreklikker på filen på webhotellet og vælger egenskaber, kan jeg tilføje skriverettigheder alle 3 steder.
Ved Ejer, Gruppe og Brugere, jeg ved ikke hvad Gruppe betyder, så den vingede jeg bare sammen med de andre.
Jeg har selv brugt ovenstående på Kims php tæller script, og derefter virkede tælleren.
Hvis det er tal der skal tastes, har jeg læst et sted, og frit efter hukommelsen at:
444 = læserettigheder, 666 = læse og skriverettigheder og 777 = alle rettigheder.
Tal på 1. position er Ejer, 2. position er Gruppe og 3. position er Brugere.
Bjarne Krogh Hansen
Bjarne Krogh Hansen
Geografisk sted: Nakskov
Re: CHMOD
Indlægaf Jørgen Rasmussen » ons okt 15, 2008 15:42
Hej Majlw
Det er sikkert ikke nok, at ændre det for mappen. Du skal nok ændre rettighederne for de enkelte filer.
Re: CHMOD
Indlægaf Kim Ludvigsen » ons okt 15, 2008 16:04
Bjarne Krogh Hansen skrev:Jeg bruger selv Vistas til at overfører filer til mit webhotel, jeg har brugt vejledningen fra Kims hæfte om KompoZer.
Det troede jeg ikke, man kunne med et netværkssted/-placering. Smart!
